BurnInTest v3.0 build 1007 running with cmd-line mode under FreeBSD 8,9 got errors.
  • splin
    • Jul 2010
    I run BurnInTest v3.0 run cmdline mode under FreeBSD 8,9 got errors.
    Error messages:
    fdb8# ./bit_cmd_line_x64
    ELF binary type "0" not known.
    ./bit_cmd_line_x64: Exec format error. Binary file not executable.
    Please advise.
    Thanks.
    The answer is still the same as last time you asked this question.
    We don't do any testing on BSD Unix and it isn't listed as a supported platform.
    • splin
      • Jul 2010
      Thanks.
      I got it.
      I will find another solution.
      Thanks for your support.
