Butterfly hard drive test
  • Glenn
    • Apr 2006
    I have noticed that when you select butterfly test in BurninTest 5.0 that when it is being tested, it still says sequential test. So is it really butterfly, or sequential? Thanks.
    I couldn't reproduce this problem. See the screen shot below.
    In what window do you see the wrong text? Is it always wrong or just some of the time? What build of V5 are you using?
    • Glenn
      • Apr 2006
      Butterfly test.
      Not sure of the build version. 1001? Anyway, I can't reproduce it myself anymore. It's the same window you are showing.
      Ok, well, now I have reproduced it. If you have more than one drive, and you check the select all hard drives box, it shows butterfly until you click on the ok button, then when you run the test, it is back to cyclic.
