There are some error during the burnintest, please help
  • chriswu
    • Oct 2017
    There are some problem occur during the burnin test.
    Disk(C-Error while reading from the disk
    Sound-No operations reported in timeout perioud.
    Not sure why have above error occurred, could you help to point out the reason?
    Attached shot is my setting before the test. Is any need to modify or the setting is too extreme?
    Sound problem is likely the sound card device driver crashing (i.e. a software fault).
    Hard disk problem is likely a real hardware error. I don't think it is a problem with your settings.
    • chriswu
      • Oct 2017
      Thanks for reply.
      That's me check, do you means if the sound error occurred caused by audio driver?
      Is possible uneven allocation of resources? seems other test item are also under testing
        "Sound card driver" and "audio driver" are the same thing.
        Not sure what you mean by this.
