Quick Burn In Test Question!
  • Scobbie
    • Jan 2013
    If I was to purchase the bootable USB flash device - http://www.passmark.com/sales/specials/index.php
    Would I be able to use it with multiple machines at the same time. Either by starting a test and then removing it to start another machine on a test or by 'cloning' the USB drive to have multiple drives to use them with multiple machines.
    The machines will have no OS at all. Maybe there is a different way other than the USB device to be able to run tests on multiple machines at the same time if the above isnt possible?
    Thanks in advance,
    Alastair
    Short answer is no.
    You can't purchase a single copy and use it on infinite machines simultaneously. You can however move it between machines. We haven't tried removing the boot drive while the operating system is running from the drive, but I suspect the result won't be pretty.
