BurnInTest v9 Pro (1002) stops too early
  • PCPKCologne
    • Apr 2018
    I bought the v9 Upgrade (previous v8 user) and configured the the test to run for 180 mins with cycles set to 0 (run infinite) but the tests are being stopped everytime in less than one hour, no matter if the result ist passed or failed, I tried it on six different PCs, with different tests, mostly CPU, RAM, 2D, 3D and disks only or with some of those disabled. What can I do to make it run for the whole 180 mins?
    Thanks in advance!
    Marco
    There was a bug in earlier build of BurnInTest that caused test to be immaturely stopped. This was fixed in Build 1003. Can you try updating to the latest release and let us know if it is not resolved?
    • PCPKCologne
      • Apr 2018
      Thanks for your reply, I should have checked for an update before posting in the forum, my mistake.The problem is now solved, thank you very much.
