USB 3.0 Loopback FW Compability
  • DPSB
    • May 2015
    • 12
    Hi there,
    i'd like to update our USB 3.0 Loopback-plugs with the latest fw 2.5
    The FAQ mentions the following:
    Firmware V2.0 and later needs BurnInTest version 8.1 build 1016 or later.
    So on windows i need at least BIT 8.1 b1016...but whats about linux?
    Does the FW 2.5 works with Linux-BIT 3.2 b1001 ?
    Also, i would like to know if the Loopbackplugs are fully supported on Windows-PE? Are there any known issues?
    Thanks in advance,
    DPSB
    • 11118
    No, that isn't supported.
    From the BurnInTest for Linux release history.
    Version 3.3 build 1003 - 22 June 2016
    • Added support for latest USB3 plug firmware (v2.0) which improves throughput
    But it has been a year since the V4 release, so we aren't supporting V3 anymore.
    WinPE should in theory be OK. But WinPE is very flexible, it is easy to build a WinPE release without the right modules and drivers and have nothing working.
