A few Issues Found with BurnInTest
  • alex8642
    • May 2018
    1. When doing USB Loopback testing, I get mouse/keyboard lag. This has been tested on multiple devices. I understand the loopback is using the maximum bandwidth available. Is there a workaround for this to allow the bandwidth for the mouse/keyboard?
    2. I had 3 RAM data verify errors. See syntax: process 3. data verify error: virtual address 0x000000006DC8EF50. Read 0x000000007195a07, expected 0x000000007195a05.
    64 bit sequence, lists 2 bits in error.
    Bad ram stick?
    3. Using WinPE Builder I have tried creating custom images to no avail. the changes to the script simply do not take, and I have no way of saving the logs as external usb sticks do not show up when plugged in to save to. I have tried different custom builders and just ran into different issues with each attempt. driver errors, crashes, etc.
    4. Using WinPE I cannot get the USB 3 loopback driver to function properly, or for instance, have the system autorun without an error, especially when i attempt to use a default.bitcfg.
    5. The system works when running from as usb stick using windows to go, but then there are other limitations, such as only being able to run one test at a time, or the mouse freezing.
    Any advice?
    I simply want to be able to run the full stress test with usb loopback on our NUC's. When I build them, i generally build 10 at a time, and stress test all at the same time. Unfortunately I am always running into some issue any way I slice it.
    • 11118
    1) Connect the mouse & keyboard to a different USB host controller. Or use a traditional PS/2 keyboard. Might also be a CPU load issue if it is a slow machine. We don't see significant lag on desktop machines with a single USB port being tested.
    2) Yes, RAM errors normally mean bad RAM. But there is a small change it is CPU or motherboard, or BIOS settings (e.g. voltage too low)
    3,4) Did you following these instructions for WinPE?
    https://www.passmark.com/support/bur...e_selfboot.htm
    I looked up the order and licenses associated with your Email address and couldn't find any. If you need more in depth support, please considering purchasing the software.
    • alex8642
      • May 2018
      1) The mouse and keyboard are already on a separate controller.
      2) Thanks. Just verifying those error codes
      3) I have followed instructions to the letter, and generally if I try to add too many drivers, or add too much extra startup code, it just crashes when building the image, so I've had to keep it basic.
      4) A win2go version works with the loopback driver/device, but WINPE won't detect the loopback device, with or without the drivers built into the image.
      License) The software is purchased - under a corporate license. I don't use our purchasing departments e-mail to browse the forum, hence there being no link to my account.
