USB2.0 loopback test
  • redly1
    • May 2006
    I purchased the USB2.0 loopback and have been trying to run tests on a USB2.0 port.
    The test runs, but it only has a throughput of 4.8Mb/sec
    I thought the USB2.0 spec was for 480Mb/sec
    Why is it not testing all the way up to this speed?
    Are you using V1.1 of the USB2Test software?
    Did the USB2 speed indication LED light up. (The Orange LED on the far left of the plug)
    Also 480Mb/sec figure is theoretical. But you should get to 300Mb/sec+
