Sound test show No operations reported in timeout period
  • NatWang
    • Feb 2019
    Sound test show No operations reported in timeout period during over night test. The trace show as below.
    Does the error cause by some Windows thread no response when BurnIn tool do some operation?
    BurnInTest V8.1 Pro 1024 (64-bit)
    Trace detail level: Activity trace 2
    System summary:
    Windows 10 Professional Edition build 17763 (64-bit),
    LOG NOTE: 2019-01-31 03:59:26, Operation watchdog for 1 is 40965919317306 (previous 3904942770968
    LOG NOTE: 2019-01-31 03:59:26, Operation watchdog for 3 is 1701488099328 (previous 1620451917824)
    LOG NOTE: 2019-01-31 03:59:26, Operation watchdog for 5 is 63558 (previous 6189
    LOG NOTE: 2019-01-31 03:59:26, Operation watchdog for 64 is 52148250 (previous 52148250)
    WARNING: 2019-01-31 03:59:26, Sound, No operations reported in timeout period
    LOG NOTE: 2019-01-31 03:59:26, Operation watchdog triggered for Sound is 52148250 (previous 52148250)
    Means the sound test has crashed or is running very very slow.
    There has been very long running issues of sound drivers leaking memory and crashing in low memory situations. No one seems to care enough to fix the sound card device driver bugs however.
    Other similar topics.
    https://www.passmark.com/forum/burni...timeout-period
    There was also a bug in the old V8 release of the software.
    https://www.passmark.com/forum/burni...2680#post32680
    So you might want to try the current V9 release.
