Burnin and Jenkins
  • teiscma
    • Feb 2019
    Burnin and Jenkins
    Hi All,
    I'm trying to run the burnin test via Jenkins .
    The command I was scripting was:
    ./bit.exe -D 1 -C "file.bitcfg" -r -x
    This command works correcly locally but it produces failures when sent remotely via jenkins.
    CPU 3 85.015 Billion PASS 0 No errors Memory (RAM) 0 0 FAIL 1 No operations during test period 2D Graphics 0 0 FAIL 4 Hardware-only DirectDraw object creation not possible 3D Graphics 0 0 FAIL 1 Unknown DirectX error Temperature - - PASS 0 No errors Sound 0 0 FAIL 1 No operations during test period Video Playback 3 46 PASS 0 No errors Serial Port 1 1 1.171 Million PASS 0 No errors Serial Port 2 1 1.183 Million PASS 0 No errors Serial Port 3 1 1.188 Million PASS 0 No errors Serial Port 4 1 1.194 Million PASS 0 No errors Have you any suggestion? Thanks a lot in advance Marco
    We've never tested BurnInTest like this, based on a description of how Jenkins works the 3D tests are likely failing as there is no output for them to connect to (and for the video test as well).
    This page suggest there is way to keep a remote desktop connection open constantly (https://stackoverflow.com/questions/...ktop-connectio) however even over remote desktop the 2D/3D tests can have issues.
    As to why the memory test failed you may need to try running the test with trace log set to level 2 to see if there is any more information about what might have caused the error. It may be there is some sort of permission issue as BurnInTest will launch a separate executable for the memory test and it may be this executable is being blocked from launching.
    • teiscma
      • Feb 2019
      .... just to improve the editing
      Hi All,
      • teiscma
        • Feb 2019
        Thanks a lot Tim! I will try your hints.
