Burn In Test 5.1 and serial ports
  • j2f
    • May 2006
    I have problem while testing serial ports with BIT5.1
    I use a home made serial board so I need to not check CTS/RTS. Whatever configuration is set, I always have errors whith these lines (CTS stuck high).
    It seems the check box is unused.
    If you have an idea...
    j2f
    Thanks for pointing this out. It seems we broke the ability to select "Disable RTS/CTS and DSR/DTR test phase" in Release 5.1 build 1002. We will correct this in BurnInTest v5.1 1005, due in the next week.
    Best regards,
    Ian
    • j2f
      • May 2006
      I downloaded rel1005. It works now.
      j2f
