Read return value from script by CVI (or C)
  • vadimgan
    • Jun 2019
    HI
    I built a script and got it from Batch file. In addition, the Batch file is activated by the system command in CVI. I can not read the return value after EXIT in the script.
    I am understanding that this is not exactly the problem of BurnInTest, but still hope for help
    Thanks in advance
    There isn't really enough detail in your post to offer any suggestions.
    Do you mean CVI (or maybe CLI?)
    • vadimgan
      • Jun 2019
      I work in CVI from National Instrument. From CVI i am calling to batch file "_1.bat", and from "1_bat" script start to run.
      In the end of script i have command EXIT.
      I want to read exit return in main CVI function
      This is main program:
      int main (int argc, char *argv[])
      if (InitCVIRTE (0, argv, 0) == 0) return -1; /* out of memory */
      if ((panelHandle = LoadPanel (0, "main.uir", PANEL)) < 0)
      return -1;
      DisplayPanel (panelHandle);
      RunUserInterface ();
      DiscardPanel (panelHandle);
      return 0;
      //func call BurnInTest
      int CVICALLBACK CVI_Start (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
      { int p_f=-3;
      switch (event)
      case EVENT_COMMIT:
      p_f=system ("C:\\Program Files\\BurnInTest\\_1.bat"); //start script
      break;
      return 0;
      File _1.bat:
      CD C:\Program Files\BurnInTest\
      bit.exe -S "C:\Projects\Hyperpack\_example by VG_script rev 1.0.bits" -R -M
      Script file:
      MESSAGE "START Test"
      SETLOG LOG yes NAME "C:\Projects\Hyperpack\Log dir\Last-LOG.htm" TIME yes REPORT text REPORt html
      SETLOG LOGLEVEL no TRACELEVEL no SUM no LINES 10000 PERIODIC 0 FILE append
      STARTLOGGING
      LOG "Start of Test
      LOG "Set up the test environment"
      LOAD "C:\Projects\Hyperpack\_config tst\_cnfg max operat CPU.bitcfg"
      LOG "RUN CPU OPERATION TEST"
      RUN CPU
      LOG "RUN 2D Graphic memory TEST"
      LOAD "C:\Projects\Hyperpack\_config tst\_cnfg 2D_graph all_mem.bitcfg"
      RUN 2D
      LOG "RUN 2D Graphic display watch TEST"
      LOAD "C:\Projects\Hyperpack\_config tst\_cnfg 2D_graph pic_run 50load.bitcfg"
      RUN 2D
      LOAD "C:\Projects\Hyperpack\_config tst\_cnfg HD cyclic.bitcfg"
      RUN DISK
      LOG "RUN NETWORK Loopback TEST"
      LOAD "C:\Projects\Hyperpack\_config tst\_cnfg net loopback internal.bitcfg"
      RUN NETWORK
      LOAD "C:\Projects\Hyperpack\_config tst\_cnfg max temperature CPU.bitcfg"
      LOG "RUN Temperature CPU TEST"
      RUN CPU
      LOG "Testing complete"
      MESSAGE "TEST FINISH"
      #Exit coomand BIT and return 0=PASS 1=FAIL after test
      EXIT
        Sorry we have never heard of CVI.
        You surely know more about it than us.
        If you are coding in C++ in Windows, then you can call CreateProcess() and GetExitCodeProcess() to launch the process and get the return code.
