Customize look/layout of interface during testing
  • jleggett81
    • Aug 2019
    This might be a feature request, but can the look/layout of BIT during testing be customized? Like instead of having temp and tests in different tabs, having them show together. Or how much detail each test shows while it is running. I.E. Which RAM test is being run.
    Depending on use case, that amount and way you see information can be useful.
    Most of the details are hard coded at the moment.
