Management Console - Reporting (Missing RAM and CPU Data)
  • Dan Baer
    • Jun 2015
    • 9
    We recently upgraded to BurninTest V9 (1017) and the latest Management Console
    I have been running through the various sections of the program and fount that in the Reporting
    section, We're not getting any statistics on the RAM or CPU's
    Could you please post some screenshots of the report types you are running so we can look into it in more detail.
    • Dan Baer
      • Jun 2015
      • 9
      Here are the RAM and CPU reports;
Name:	Missing RAM List.png
Name:	Missing CPU List.png
      The HDD report seems good !
        Thanks for the screenshots. Currently the Lists are only in a partially implemented state, the HDD should be working but the CPU and RAM lists are only partially implemented.
        Specifically the RAM list for BurnInTest has no data to work with, only MemTest currently populates the required database table. We’re about to do a new public release of BurnInTest so we’ll see if we can start populating this table from BurnInTest connections as well.
        The CPU list currently isn't currently querying the database correctly to display results so we'll look at fixing this.
          Updates have now been made to the management console and BurnInTest to improve the list creation.
          • Dan Baer
            • Jun 2015
            • 9
            Thanks Tim,
            Cant wait to give them a try. Sorry for the slow response, we have been really busy.
