Burnintest Serial Test in different operating system
  • harrycc
    • Aug 2019
    We conducted the serial test of Burnintest in the following conditions under Windows and Linux. However, we got different results and have a few questions about it.
    Test 1:
    Operating system: Windows 10 Pro 64bit
    Burnintest version: Burn in Test V 9.1 (1001)
    Burnintest test item: Serial test
    Serial Port #: 1
    Test Result: Run for 16 hours pass without errors
    Test 2:
    Operating system: CentOS 7.6 (1810) 64bit
    Burnintest version: Linux Burn in Test V 4.0 (1003) cmdline version
    Serial Port #: 1
    Test Result: Fail and error occurred "Corruption. Data received didn't match data sent"
    All other conditions are the same in these two tests, including system, RAM, hard disk, COM port number, etc.
    Q1. Since the system and other configuration is the same except for the OS, what is the possible cause of the different results in different OS??
    Q2. What is the difference of the serial test algorithm between Windows and Linux burnintest??
    Please help answer the questions, thank you!
    Best,
    Harry
    • 11114
    Serial ports were never meant to be error free. If you run the test long enough a few errors are to be expected.
    Pretty much all usage of serial ports used protocols to detect & correct errors (Kermit, XMODEM, YMODEM, FTP, etc..) .
    A large number of errors in a short time (compared to the amount of data transferred) would indicate a problem however.
    • harrycc
      • Aug 2019
      We conducted the test only using simple loopback and with Tx/Rx only. Also, the transfer rate was set to be 115200. Currently, when running in Linux burnintest, an error would occur every 2-4 minutes in average. However, with the exact same system settings, no error would occur in Windows burnintest. That is why we would like to know the difference of the serial test algorithm between Windows and Linux burnintest. Please help answer the question, thanks!
        • 11114
        We don't support home made loop back plugs.
        Can you make one to our specs (or buy one of ours) and see how it goes
        https://www.passmark.com/products/lo...ifications.php
        (there are certain test options that need more than Tx/Rx connected)
        • harrycc
          • Aug 2019
          We simply use a common jumper to short Tx and Rx pins, since all other pins (except for GND) of the COM port are no connect by design of our system. In addition, we have activate the "DisableRTS" option in the cmdline_config file for Linux burnintest. Under such circumstances, the loopback should work as it does in Windows burnintest. Therefore, my question would still be the serial test algorithm differences between Linux and Windows burnintest. Please help answer this question, thanks!
          • harrycc
            • Aug 2019
            Any update on this issue??
            • jerry
              • Apr 2020
              Hi David,
              Any update on this issue ?? We also encountered the same problem
              Test 1:
              CPU:intel(R) Xeon(R) Gold 6238T CPU @1.9GHZ X2
              MemoryDR4 2666 128GB
              Operating system: Windows 2012 R2 64bit
              Burnintest version: Burn in Test V 8.1 (1025)
              Burnintest test item: Serial test (Baud Rate: 9600)
              Serial Port #: 1 & 2 & 3
              Test Result: Run for 12 hours pass without errors
              Test 2:
              Operating system: CentOS 7.5 64bit
              Q1. Since the system and other configuration is the same except for the OS, what is the possible cause of the different results in different OS ??
              Q2. What is the difference of the serial test algorithm between Windows and Linux burnintest ??
                • 11114
                There is no update as we aren't looking at the problem.
                1) We don't support home made loop back plugs.
                2) Serial ports were never meant to be error free. If you run the test long enough a few errors are to be expected. A large number of errors in a short time (compared to the amount of data transferred) would indicate a problem however.
                Windows and Linux will use different serial port device drivers, typically supplied by the motherboard vendor.
