I am using the loopback plugs for an automated test on a system with 4 usb 3.0 ports.
Sometimes, 1 or more plugs aren't recognized and appear as "Unknown Device" in Windows's Device Manager
From what i can see, unknown device have a VID=0x0000 and a DID=0x0000. But do have the other 3 plugs as siblings.
If I Unplug and reconnect the faulty plug physically, everything goes back to normal but this is not a valid solution.
Here are the steps I do to create the problem :
1. Plug the loopbacks in the system
2. Power up the system from G3 to S0
3. Boot Windows 7
4. Run the test
5. Shutdown the system to G3
6. Start over
And the problems occurs more than 1 out of 4 times.
I run windows 7 with Intel(R) USB 3.0 eXtensible Host Controller version 1.0.10.255
(I also tried 1.0.9.254)
If I disable XHCI in the BIOS or use USB2.0 ports, there is no problem but again this is not a solution.
Do you have any idea of what I might be doing wrong?
I have screenshot and can reproduce it easily so if you want them by email just ask
fsim
3. Boot Windows 7
4. Run the test
6. Start over
fsim
