Any hardware from Passmark that supports USB3.2 speed test?
  • Haur
    • Apr 2020
    Hi guys,
    Does Passmark produce USB loopback testers that are capable of handling USB3.2?
    I've seen the current product only capable of handling up to USB3.0.
    Please advise.
    Thanks.
    Haur
    To be really pedantic, the current USB3 loopback plug does support 3.2.
    But it only supports USB 3.2 Gen 1. Which is 5Mbit/s (and was in the past called both 3.0 and also 3.1. The USB naming is insane)
    But I assume you are really looking for USB 3.2 Gen 2 or USB 3.2 Gen 2x2. Which we don't have yet.
    We are looking at it. But at the moment there is no cost effective solution. Maybe by around the end of 2020 it is possible to build a fairly cheap solution.
    • ekearney
      • Jun 2025
      Hi There,
      Does the new Infineon FX20 USB 20 Gbps Peripheral Controller offer you a cost effective solution to make a USB 3.2 Gen2 or gen 2x2 tester?
      Regards
      Erik
        We purchased a couple of the new FX20 (20Gbps) hardware development kits for evaluation. They are so new the documentation is only half complete, but they seem promising in the initial testing we have done. We are optimistic that this might be the cost effective solution we've been waiting for.
        As you can see from the time line of the posts above, it has taken way longer than expected for silicon to become available. We tried a few other solutions over the last few years. Some were technically impossible. Some sounded good on paper, but when we tried to order the chips they weren't actually available. One company refused to supply chips and documentation unless we ordered maybe 20,000 units up front and also allowed them to dictate the design. One worked really well but was crazy expensive and wanted ongoing royalties (maybe $1000 / unit by the time we got it to retail). Hardware development isn't easy.
        • ekearney
          • Jun 2025
          Hi David,
          Look forward to seeing what you can achieve it the FX20.
          I agree that some chip manufacturers do put unreasonable roadblocks in the way of people using their ICs, it doesn't make a great deal of sense.
          Regards
          Erik
          • Derek@Sealevel
            • Nov 2011
            • 14
            Is there a timeframe for this effort? I know previous concepts did not pan out but this solution does look encouraging...
              There are a number of technical issues we are working through. These include very high idle power usage (leading to high chip temperatures), the ability to re-enumerate down to lower speeds to test older USB modes, the lack of a usable boot-loader for in the field firmware updates, collection of accurate error counters, etc...
              Most of these issues seem solvable at the moment.
              Hardware development is a slow process however. So we need to design a printed circuit board (probably with 1 or 2 rounds of prototyping), decide what type of enclosure we need, get plastic moulds made (also probably with rounds of prototyping) order & test E-Marked cables, decide if we need a cooling solution as these high speed chips run hot, sort out packaging, sort out how the QA testing will work, get device drivers signed by Microsoft, then do bulk production, etc...
              So no date yet for retail sale. But this year, unless something really unexpected happens.
              • Derek@Sealevel
                • Nov 2011
                • 14
                If I can make a suggestion...Please consider making provisions for adding some extra load to stress power rails close to the port limit. Either built-in or through external connection.
                  We've already got an available solution for stress testing USB power rails. Up to 240W in fact.
                  • Derek@Sealevel
                    • Nov 2011
                    • 14
                    Yes, I'm aware. We have one and like it. But I'd need one of those per port and for moderate load of a standard port it's an overkill. Software-controlled power rail connector addition to the loopback wouldn't add much cost but a lot of versatility.
                      The power rail in type-C isn't just a simple wire with a fixed voltage. It is complex. Very complex. There are multiple standards, multiple profiles, a wide range of different voltages, a negotiation process with the host and the cable to determine available profiles, there are also 4 voltage rails and two ground, etc...
                      Having exposed pins also greatly increases the risk of blowing things up. Either short circuits or dumb loads with too little resistance (i.e. accidentally connect a 200W / 1A load at 20V and pull 20A. So briefly draw 400W until the magic smoke leaves the device being tested). I think this is the main downside, we already have customers blowing stuff up and it takes a huge amount of support time to deal with it. Maybe in the medium term we can expose the pins and also have some semi-dumb external load. Dumb, but with some protection circuits.
                      • Tomas Filip
                        • Aug 2016
                        Hi Passmark team,
                        If I may make a suggestion or request, it would be very practical for our needs if the enclosure had at least two mounting holes, which would allow us to securely mount several USB devices on top of each other (stack-up).
                        The second wish, which is based on our daily use of previous loopbacks, is to have an industrial version (the chip allows this). The temperature chambers in which we test our products are relatively large, and placing the adapter outside forces us to use a 1m USB cable, which is contrary to the specification.
                        I think that a small price add-on for a slightly larger USB tester, even without a display (we read the data from the SW), but with a small passive cooler and industrial temperature range, will be offset by larger purchases and the replacement of USB 3.0 testers.
                        With regards
                        Tomas Filip
                          To add a heat sink & holes would require a larger case. Plastic molds can cost around $10K. Maybe it is possible to get all the components rated up to maybe 80C, but this would surely also add to the cost. Likely firmware changes would also be required to keep the accuracy of voltage measurements, etc..
                          We'd need to sell 1000s of units (at a higher price) to justify this. Which seems unlikely as they are a fairly specialized piece of kit. How many do you need?
                          We are working on a new version at the moment, which will have a heat sink. But it runs at 20Gbit/s and really does need the heat sink, even at ambient temperatures.
                          Might make more sense for you to get a bracket made up for mounting the existing unit. If you were careful you could also remove the case and add your own heat sink (no warranty on this however).
                          • jd.phillips
                            • Nov 2012
                            • 28
                            Passmark Team,
                            Any updates on the original topic of this post?
                            Thanks!
                              We have a 20Gbit/sec version working in house. We did an initial prototype, but found some issues, which are fixable. Should be sending 2nd prototype to assembler next week, maybe to get around 10 units done.
                              So we are still working on it. But we are very confident this product will go to volume manufacturing now. The hard bit (the R&D part) is done.
