Linux BIT CLI how to create a BIT Certificate
  • Exellent
    • Aug 2020
    • 14
    Hy Is there any chance to create the BIT Certificate ( which is possible in the gui version) also with the commandline version?
    You can use the certificate by editing the <Logging> section of the cmdline_config.txt file and changing the Format to Certificate (instead of Ascii or HTML).
