I have a bootable flashdrive containing Ubuntu Linux. I copy the BIT archive to it, tell it my licence key, extract files, save to a BIT folder and run a BIT test on a new computer. Upon removing the flashdrive and plugging it into another test computer, BIT isn't there. Surely I don't have to download, give it the licence key, etc all over again for every test. I probably don't know enough about Linux to make the installation permanent. What am I missing?
BIT Disappears from Flashdrive after One Use
Tags: None
Are you copying BurnInTest to the physical USB drive or part of the live environment when it is running? As the live environment only exists in memory when you shutdown/remove the drive then anything copied there will no longer exist.
We have some examples of creating live boot environments using Ubuntu and Slax here. -
