Announcement
No announcement yet.
BurnInTest Linux V2.1 & V3.2 Serial port speed problem
  • Filter
  • BurnInTest Linux V2.1 & V3.2 Serial port speed problem
    I'm using BurnInTest to verify PC serial port. I'm confused when I using v2.1 to test PC serial port, it's can be full speed (115200bps). But when I using V3.2 to verify ports, the speed down to 2000~3000bps.
    I'm try it on the same computer & os (Ubuntu 14.04) & the same settings. Serial Port duty had set to 100, baudrate set to 115200 and Loopback with DisableRTS.
    Thanks.
  • #2
    Thanks for reporting this, we've identified a sleep that could be too long during the test cycle that was causing the slow throughput. This will be fixed in the next public release.
    • #3
      The bug is fixed with v3.2 build1001
      Thanks a lot
