BIT 9.2 Issue
  • DChrisD
    • Jan 2021
    BIT 9.2 Issue
    Guys - the new ver of BIT (9.2) stops responding on the part where it searches for sources of heat sensing... Happens every time I run it. Any ideas at all??
    Going to try on a bunch of other machines to see if its just my main one.
    Chris
    Yes, try it on another machine.
    Then send us the log file & hardware specs.
    https://www.passmark.com/support/bitdebug.php
    • DChrisD
      • Jan 2021
      OK, weirdness!! what's causing this is my Corsair Survivor Stealth 128Gb USB stick. With it plugged in (to any USB port) the BIT software stops, - out it all works fine. I have tried other USB drives and they don's cause the issue. Ultra - odd!! I DO have the BIT portable on that drive though????
      Chris
        We did see similar behaviour with one of our USB drives here a week back as well.
        The USB drives claims to support SMART, but then locks up when a request is made to get the SMART data.
        Can you send the log files to us. Thanks.
          We believe this problem is caused by some USB drives triggering timeouts when BurnInTest is checking for temperature sources, could you please try this build.
