Dear Members,
I have two Intel E5-2667 v2 processor installed on a s2600 g/z Intel Board.
Looking at the Burnin test LOG file I noticed the test is executed only on Cores 1-2-3-4 of each CPU's
I tried different configuration with no luck.(see below)
Any advice on how to test all the Cores ?
Thanks!
Davide
PassMark BurnInTest Log file - http://www.passmark.com
Date: 10/23/14 10:54:41
BurnInTest V8.0 Pro 1009 (64-bit)
System summary:
Windows 8 Ultimate Edition build 9200 (64-bit),
2 x Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz,
31.9GB RAM,
2 x 932GB HDD,
General:
System Name: MININT-FDEUL1C
Motherboard Manufacturer: Intel Corporation
Motherboard Name: S2600GZ
Motherboard Version: G11481-354
Motherboard Serial Number: QSGR42102875
BIOS Manufacturer: Intel Corp.
BIOS Version: SE5C600.86B.02.03.0003.041920141333
BIOS Release Date: 04/19/2014
CPU:
CPU Type: Intel(R) Xeon(R) CPU E5-2667 v2 @ 3.30GHz
Codename: Ivy Bridge-EP
CPUID: CPU1: Family 6, Model 3E, Stepping 4
CPUID: CPU2: Family 6, Model 3E, Stepping 4
Socket: LGA 2011
Lithography: 22nm
Physical CPU's: 2
Cores per CPU: 8
Hyperthreading: Disabled
CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX SMX Turbo AES AVX FMA3
Clock frequencies:
- Measured CPU speed: 3293.0 MHz
- Base Clock: 100.0 MHz
Multiplier range: Min: x12, Max non turbo: x33
Cache per CPU package:
- L1 Instruction Cache: 8 x 32 KB
- L1 data cache: 8 x 32 KB
- L2 cache: 8 x 256 KB
- L3 cache: 25 MB
RESULT SUMMARY
Test Start time: Thu Oct 23 10:44:37 2014
Test Stop time: Thu Oct 23 10:47:21 2014
Test Duration: 000h 02m 44s
Temperature CPU 0 average (Min/Current/Max): 37.8C / 69.5C / 72.5C
Temperature CPU 0 core 0 (Min/Current/Max): NA / NA / NA
Temperature CPU 0 core 1 (Min/Current/Max): 35.0C / 68.0C / 71.0C
Temperature CPU 0 core 2 (Min/Current/Max): 38.0C / 71.0C / 73.0C
Temperature CPU 0 core 3 (Min/Current/Max): 40.0C / 71.0C / 75.0C
Temperature CPU 0 core 4 (Min/Current/Max): 38.0C / 68.0C / 71.0C
Temperature CPU 0 core 5 (Min/Current/Max): NA / NA / NA
Temperature CPU 0 core 6 (Min/Current/Max): NA / NA / NA
Temperature CPU 0 core 7 (Min/Current/Max): NA / NA / NA
Temperature CPU 1 average (Min/Current/Max): 45.8C / 63.8C / 74.8C
Temperature CPU 1 core 0 (Min/Current/Max): NA / NA / NA
Temperature CPU 1 core 1 (Min/Current/Max): 46.0C / 63.0C / 75.0C
Temperature CPU 1 core 2 (Min/Current/Max): 44.0C / 64.0C / 75.0C
Temperature CPU 1 core 3 (Min/Current/Max): 47.0C / 66.0C / 76.0C
Temperature CPU 1 core 4 (Min/Current/Max): 46.0C / 62.0C / 73.0C
Temperature CPU 1 core 5 (Min/Current/Max): NA / NA / NA
Temperature CPU 1 core 6 (Min/Current/Max): NA / NA / NA
Temperature CPU 1 core 7 (Min/Current/Max): NA / NA / NA
Temperature HDD 0 () (Min/Current/Max): 28.0C / 28.0C / 28.0C
Temperature HDD 1 () (Min/Current/Max): 28.0C / 28.0C / 28.0C
CPU 10 2.242 Trillion PASS 0 No errors
Temperature - - PASS 0 No errors
TEST RUN PASSED
DETAILED EVENT LOG
LOG NOTE: 2014-10-23 10:44:37, Status, PassMark BurnInTest V8.0 Pro 1009 (64-bit)
LOG NOTE: 2014-10-23 10:44:39, Status, Main Tests started
LOG NOTE: 2014-10-23 10:47:21, Status, Test run stopped
Thanks!
Davide
System summary:
31.9GB RAM,
2 x 932GB HDD,
General:
CPU:
Socket: LGA 2011
Lithography: 22nm
Physical CPU's: 2
Cores per CPU: 8
Clock frequencies:
- L3 cache: 25 MB
RESULT SUMMARY
TEST RUN PASSED
DETAILED EVENT LOG
