Announcement
No announcement yet.
Unexpected error running DirectX 12 Test. Error Number 8899000C (-2003238900)
  • Filter
  • Unexpected error running DirectX 12 Test. Error Number 8899000C (-2003238900)
    Dear Admin,
    I'm encounter this error when graphic set as Auto, while set as DirectX 9 the 3D Graphic test pass without any error which facing as below:-
    LOG NOTE: 2021-01-18 12:21:22, 3D Graphics, Unexpected error running DirectX 12 Test. Error Number 8899000C (-2003238900)
    LOG NOTE: 2021-01-18 12:21:22, 3D Graphics, There has been a presentation error that may be recoverable. The caller needs to recreate, rerender the entire frame, and reattempt present.
    LOG NOTE: 2021-01-17 10:08:25, 3D Graphics, Unexpected error running DirectX 12 Test. Error Number 8899000C (-2003238900)
    LOG NOTE: 2021-01-17 10:08:25, 3D Graphics, There has been a presentation error that may be recoverable. The caller needs to recreate, rerender the entire frame, and reattempt present.
    LOG NOTE: 2021-01-17 12:11:26, 3D Graphics, Unexpected error running DirectX 12 Test. Error Number 8899000C (-2003238900)
    LOG NOTE: 2021-01-17 12:11:26, 3D Graphics, There has been a presentation error that may be recoverable. The caller needs to recreate, rerender the entire frame, and reattempt present.
  • #2
    There is a newer driver available for your graphics card which you should install to see if that stops the error occurring.
    Are you able to run the 3D test by itself? As this is a low powered integrated card it may be running out of resources while running the other tests.
