Announcement
No announcement yet.
BiT 9.2 1k2
  • Filter
  • BiT 9.2 1k2
    Hi everyone
    as topic "9.2 issue" & "BurnInTest is hung on “Detecting temperature sources. Please wait...”
    I try new version of Bit. But have same problem if Bit detect a card reader.
    if I disconnect the card reader the program works perfectly
    Hints?
    thank
  • #2
    Could you please launch BurnInTest in debug mode and send us the log files.
    Could you then try launching BurnInTest with the command line parameter NOTEMP, this will disable temperature monitoring and should allow BurnInTest to launch.
    • #3
      https://1drv.ms/u/s!AoLZDKc7nn3OmFpS...wcr6G?e=ItaJ4I
      this is log files.
      with parameter NOTEMP I don't have any problem
      • #4
        Hi, news for this?
        or: can I still see if the system temperature is too high with the NOTEMP parameter?
        • #5
          Can you launch BurnInTest in debug mode with the card reader attached and send us the log files after trying to start BurnInTest.
          • #6
            e-mail sent
