How to set the Burnintest 4.1 1001 CPU temperature
  • aiden0611
    • Feb 2021
    As mentioned in the title, how to set the CPU temperature under cmdline so that the production line can see whether CPU OVER SEPC appears.
    > OVER SEPC
    Maybe you mean "over temperature" ?
    • aiden0611
      • Feb 2021
      Use the BIT of the GUI interface to define the CPU temperature in the items that can be set. See the red box in the image below. But in Burnintest 4.1 1001, can't I find a place to set the CPU temperature.Click image for larger version
        These settings can't be changed via command line, you can use the SETTEMP script command as part of a script though (see the "Scripting test preferences" section of the help file).
        As for Version 4.1.1001 this is some 17 years old now and temperature support was very limited in this version so I don't believe those options existed.
