USB Stick (build 1002) - Could not open saved configuration file
  • supporto@buyernet.it
    • Aug 2021
    • 8
    Hi.
    I have created a usb stick and configured my personal path to video test, my personal path to store the Test Certificate, etc. but when i started to test it show me this windows then it load the defaut parameters and it starts in default mode.
    Until v9.2 it worked flawlessly.
    How are you launching BurnInTest, running the executable directly or by scripting the launch with some command line parameters?
    So far we haven't been able to reproduce this, when installed and run from a USB it should be looking for the last used configuration file in the Configs directory on the USB drive (eg H:\BurnInTest\Configs).
