BurninTest V9.2 1007 Temperature error
  • Hamada
    • Dec 2021
    At what temperature or higher will an error occur?
    What are the conditions under which a temperature error occurs?
    i7-1165G7
    • 335
    By default its set at 90C - if CPU reaches over 90C, an error/warning will occur, you can change this in Configuration > Test Preferences... > Temp/Battery tab > Auto Thresholds
