Hello Sir, We see the waring message as the attached photo. Does it mean the system use battery power to run BurninTest and the battery power is low? Or what conditions does the waring message window be pop-up?
BurnInTest 9.2(1009) Waring, Running the DX12 3D test..lauches on low powered systems
This error message is displayed when the CPU and 3D test are set to 100% duty cycle. On low performance systems (those with integrated graphics cards, low power CPUs and limited RAM, etc) the DirectX12 test will often timeout due to the limited system resources available.
The situation is exacerbated on system with low RAM, where disk swapping might occur.
