problem with BartPE ramdisk in BurnInTest
  • yannickd
    • Aug 2006
    I have created a BartPE Live CD with BurnInTest, to test new servers.
    On startup all the available disks are automatically mounted and formatted.
    After that BurnInTest automatically starts for 48 hours.
    Now I checked "Select all Hard Drives" in burnintest configuration but when the
    test runs it obviously also tests the B: RamDisk, which gives errors during the test.
    Code:
    INFORMATION: 2006-08-25 18:06:33, Disk, B: Test file could not be created
    LOG NOTE: 2006-08-25 18:06:33, Disk, File name: B:\~bittestB00001, Error Code: 32
    Is there a way to exclude this one disk from the test?
    There are really only two options as far as the selection of hard drives go.
    You can either automatically select all drives for testing or you can pick a fixed list of drives to test.
    If each machine you test is different and the automatic option doesn't work for you, then you could create 2 or 3 different configuration files. Each configuration file would be preset with a different combination of drive letters, corresponding to your common disk configurations.
    Another possibility might be to work out why there is an error creating a file on the RAM disk, then use the automatic option.
    • yannickd
      • Aug 2006
      There was something wrong with the disk mounting program, now it seems to work fine. But thanks anyway for replying.
