Bunrin test Temp problems
  • stenfeldt
    • Feb 2022
    hello
    i using your software to test Pc systems at my workplace, we have some problems with the new version 10.1 (1002) when your software is running pc test it logs the temps, but when it
    exceeds the 90C threshold, the Test does not show an error, if you look in Event log is shows error Tempature Threshold exceeded but why does the Dashboard screen not show an error, and when the test is complete is still shows as a passed test, even when the event log shows Tempature threshold exceeded i never had this problem with v9.1
    Best regards mikkel
    Under the Test selection and duty cycles dialog did you check the Temperature checkbox?
    It seems to be working with a quick test when I set the threshold to 40 to trigger the errors.
