BIT won't start when Windows 10 boots.
  • jd.phillips
    • Nov 2012
    • 28
    I cannot get BIT v9.0 Pro to start when Windows 10 boots. I've tried the following:
    1. Placing a shortcut in the Startup directory. All the properties seemed to check out. This worked with a different program.
    2. Creating a Task.
    3. Adding the recommended string to "win.ini".
    4. Editing the registery.
    Any suggestions?
    Can you post a screen shot of the Short cut properties.
    (especially the executable name)
    If you manually double click on the short cut does it work?
    • jd.phillips
      • Nov 2012
      • 28
      Yes, manually running the shortcut worked fine. I was finally able to get it to work by creating a batch file and sticking that in the Startup directory. Would you still like to see a screenshot of the shortcut properties?
        If it is working, there is probably no need to fix it.
