Burnin Test showed cpu temperature critical. What should I do.
  • paulcopeland
    • Apr 2015
    g'day from Australia.
    I have just downloaded the demo of BurninTest
    I ran the diagnostics and the one problem that showed was the temperature CPU threshold becoming critical.
    For example
    LOG NOTE: 2015-04-26 14:32:59, BurnInTest, Temperature CPU 0 average: Current 93.5C / Threshold 90.0C
    What steps should I take to resolve this issue? I have no idea regarding hardware.
    Thank you for your help.
    Paul.
    Ps. The system that I have is
    The system that I have is Windows Xp Professional
    processor Intel i7 cpu 960 @ 3.20 Ghz 3.20 GHz
    Installed memory (ram) 24.GB
    System type 64-bit Operating system
    • 11112
    Check that all the fans are working
    Check that the box isn't full of dust.
    Check that the heatsink is attached correctly to the CPU.
