Burn in Test Certificate how to include GUID / UUID
  • Lamprecht
    • May 2015
    as discussed on http://www.passmark.com/forum/showth...st-Certificate
    I would need the GUID UUID settings as well in the certificate.
    We produce industrial computers and every system must have an GUID that matches the system serial number. We test our systems with Burn In Test on a USB stick
    You can read the GUID settings in windows with the following lines
    @echo off
    echo Windows GUID Einträge
    wmic bios get serialnumber / format:list >zeige.txt
    wmic computersystem get OEMStringarray /format:list >>zeige.txt
    wmic baseboard get Configoptions /format:list >>zeige.txt
    wmic baseboard get serialnumber /format:list >>zeige.txt
    type zeige.txt
    would this be possible to integrate in the Burn in Test suite that we can test a system via USB stick and have the GUID noted in the certificate or is it already included and I was only unable to find it?
    Thanks in advance
    Gunter Lamprecht
    What you are calling the BIOS serial number UUID isn't a UUID on most systems.
    In BurnInTest this field is called "System Model" and on my test machine the value of this field is just, "To Be Filled By O.E.M.".
    This already appears in the reports generated by BurnInTest. It looks like this,
    System Model: To Be Filled By O.E.M.
