CPU Temp test - Failed Found 1 Error - Help to solve plz
  • Zille79
    • Oct 2022
    Hey Pro:s out there!
    I just made a CPU temp test and received 1 Error. Now is just the question, how and what is wrong?
    Error message: Temperature threshold exceeded.
    I've changed the thermal paste and have good cooling (Corsair - water radiator)
    Se results below:
    RESULT SUMMARY
    Test Start time: Sun Oct 2 15:07:31 2022
    Test Stop time: Sun Oct 2 17:07:39 2022
    Test Duration: 002h 00m 08s
    Temperature CPU 0 average (Min/Current/Max): 71.4C / 88.8C / 90.4C
    Temperature CPU 0 core 0 (Min/Current/Max): 67.0C / 85.0C / 87.0C
    Temperature CPU 0 core 1 (Min/Current/Max): 67.0C / 85.0C / 87.0C
    Temperature CPU 0 core 2 (Min/Current/Max): 69.0C / 85.0C / 88.0C
    Temperature CPU 0 core 3 (Min/Current/Max): 69.0C / 85.0C / 88.0C
    Temperature CPU 0 core 4 (Min/Current/Max): 74.0C / 89.0C / 91.0C
    Temperature CPU 0 core 5 (Min/Current/Max): 74.0C / 89.0C / 91.0C
    Temperature CPU 0 core 6 (Min/Current/Max): 74.0C / 91.0C / 93.0C
    Temperature CPU 0 core 7 (Min/Current/Max): 74.0C / 91.0C / 93.0C
    Temperature CPU 0 core 8 (Min/Current/Max): 73.0C / 90.0C / 93.0C
    Temperature CPU 0 core 9 (Min/Current/Max): 73.0C / 90.0C / 93.0C
    Temperature CPU 0 core 10 (Min/Current/Max): 72.0C / 90.0C / 91.0C
    Temperature CPU 0 core 11 (Min/Current/Max): 72.0C / 90.0C / 91.0C
    Temperature CPU 0 core 12 (Min/Current/Max): 71.0C / 90.0C / 90.0C
    Temperature CPU 0 core 13 (Min/Current/Max): 71.0C / 90.0C / 90.0C
    Temperature CPU 0 core 14 (Min/Current/Max): 71.0C / 90.0C / 90.0C
    Temperature CPU 0 core 15 (Min/Current/Max): 71.0C / 90.0C / 90.0C
    Temperature HDD 0 (WD_BLACK SN750 2TB) (Min/Current/Max): 41.0C / 48.0C / 49.0C
    Temperature GPU 0 (NVIDIA GeForce RTX 3090) (Min/Current/Max): 36.0C / 42.0C / 42.0C
    CPU 1350 1.4 Quadrillion PASS 0 No errors
    Temperature - - FAIL 1 Temperature threshold exceeded
    TEST RUN FAILED
    DETAILED EVENT LOG
    LOG NOTE: 2022-10-02 15:07:30, Status, PassMark BurnInTest 10.1 1003 (64-bit)
    LOG NOTE: 2022-10-02 15:07:33, Status, Main Tests started
    CRITICAL: 2022-10-02 16:22:50, Temperature, Temperature threshold exceeded
    LOG NOTE: 2022-10-02 16:22:50, BurnInTest, Temperature CPU 0 average: Current 90.1C / Threshold 90.0C
    LOG NOTE: 2022-10-02 17:07:39, Status, Test run stopped
    What CPU model? Some are rated to work over 90C.
    Insufficient cooling is the most likely cause (or too much overclocking)
