How to read burn in test test report
  • shinji0426
    • Oct 2022
    Hi all:
    I just finished my first burn in test and got the result, but I have prolbems about how to read and interpret the report.
    For example, I got test result of CPU cycle with 462, and operations 31.435 trillion. Are these numbers bigger the better?
    BurnInTest is for system stability and stress testing. If there are no errors during your run, then the system passed based on the option you set in the configuration.
    If instead, you are interested in Performance metrics, you should use our PerformanceTest software instead for benchmarking.
