ERROR Making BurnInTest Self Bootable with PassMark WinPE Builder
  • David Alarcon
    • Nov 2022
    I don't know how to solve the problem.
    I have BurningTest V9.2 and Windows 10 Pro 64 21H2.
    I follow all the steps in the explanatory video but I get this error. I use an 8GB flash drive and I unformat it.​
    WinPEBuilder is a helper utility to build the WinPE image, it creates the batch script to automate the process using the tools provided by Microsoft. Make sure that WinPE Addon from the ADK is actually installed. Microsoft separated the two. Refer to the following post, https://forums.passmark.com/other-so...5737#post45737
    Or you can run "-K" command line parameter with WinPEBuilder. This will prevent the batch script that WinPEBuilder creates to build the image from being deleted. The batch script, _winpebuild.cmd, is located in the Temp Working Directory that you specify. Then you can try to run the batch script in a command prompt to see which part of the build is failing.​
    If all else fails, you can manually build the WinPE image, WinPEBuilder is based off this guide, https://www.passmark.com/downloads/BIT_WinPE.pdf​
