GPGPU test doesn't show device
  • ua@adv-tech.it
    • Feb 2023
    We have a system equipped with two GPU NVIDIA A2 Tensor Core devices.
    But, once added GPGPU test module, they are not tested because GPGPU test module configuration shows cpu integrated graphics device only, and nothing more.
    From Device manager both Nvidia A2 are correctly installed with their drivers.
    What can we do add these devices to burnin test?
    Thanks,
    Francesco
    The GPGPU test uses DirectX (Direct Compute to be exact) and requires a monitor connected to the card. If the card doesn't support these requirements, then BurnInTest will not be able to test it.
    • ua@adv-tech.it
      • Feb 2023
      Hello Richard,
      very thanks for reply & info.
      Since these are GPU cards (and not so cheap ) it would be very useful to implement something to test it also.
      Very thanks for support!
      Cheers,
      Francesco
        We'd like to add support as well.
        But as you say, the hardware isn't cheap at all.
        Maybe we can source the older generation of cards 2nd hand and hope they work the same as the newer ones.
