Trace filename doesn't use define "LogPrefix"
  • dragon76vn
    • Mar 2023
    BurnInTest v5.0 (1003) Linux 64bit
    ## Location (path) of log file
    LogFilename /tmp/
    ## Log prefix
    LogPrefix test1234​
    These are my setting and when the test is finished, I get "test1234.log" and "BIT_log.trace". I used v3.3 before and it produced "test1234.trace". How can I get the same for v5.0? Thanks.
    Can you add this config command,
    LogMode Timestamp
    And make sure there is no other setting for "LogMode"
    See also BurnInTest Linux User's guide
    • dragon76vn
      • Mar 2023
      LogMode Timestamp
      LogMode Timestamp will give me multiple new timestamped files correct? I don't want that. I need the trace file to have LogPrefix name that I assigned.
        • 335
        Can you try running this build which should address the .trace not being renamed:
        https://www.passmark.com/downloads/t...0230307.tar.gz
        • dragon76vn
          • Mar 2023
          Yes, it works. So, can I use this and import my key or wait for an official release?
            • 335
            You can continue using this build until we do a official release.
