Capture of Test data
  • dmachen
    • Sep 2015
    Currently using your software, we capture your test logs as text files, but I would love to get information on test results as part of a database or excel file showing me the serial numbers and test results. We are currently using multiple software programs to capture the information needed to qualify a SSD Drive. We use HDBench to capture read, write, random read, random Write speeds. We use Burn in test to do a cyclic test on all of our drives and need to capture the serial number, and test results. Does your software do this?
    BurnInTest can produce reports in Text and HTML format.
    It can also optionally send the reports to the the BurnInTest management console which stores the results into a SQL database. So maybe that is a good solution, or maybe writing a script to parse the text output is an option.
