High memory latency detected during burn-in test using Passmark 7.0 Pro
  • ISIC-Service
    • Sep 2015
    We have experienced a number of systems, that during burn-in has shown wrong memory information in the burn-in rapport.
    Same type of memory module, Kingston Value RAM DDR3 4GB 1333MHz CL9.
    Example (incorrect memory information):
    DDR3 SDRAM PC523600
    SSTL 3.3V, Clk: 909.1MHz, Timings 7-219-55-120 (@ Max. freq.)
    Example (The correct memory information, what it should be like):
    4GB DDR3 SDRAM PC3-10600
    Kingston 9905403-555.A00LF, serial#: 891203806
    1.5V, Clk: 666.7MHz, Timings 9-9-9-24 (@ Max. freq.)
    As the systems has passed the burn-in test, we are looking into if it is Passmark that are providing wrong information in the burn-in rapport and what could be the cause of this.
    /Peter Petersen
    ISIC
    Service
    Can you try using the current version of BurnInTest (V8.1) and see if the data looks correct.
    Getting the correct information depends on the CPU & Motherboard in use. So if it isn't correct in V8.1 can you provide the full system details.
    • ISIC-Service
      • Sep 2015
      Thank you for the quick reply David.
      Unfortunately we do not have one of the original memory modules to test on.
      But if I can Refer to another post on your performance board which looks very similar to mine, did you find out what the problem was in that post?
      http://www.passmark.com/forum/showth...memory-latency
        The other post was from around a year ago.
        I would be fairly sure it was a bug that was corrected since then.
