BurnIn Test v10.2 build 1003-Error Number 0x8007000E (-2147024882)
  • Ben CE Chen
    • Jun 2023
    It dispaly "Unexpected error running DirectX 12 Test. Error Number 0x8007000E (-2147024882)" in BurnIn Test,
    Then add BurnInTestLog and BIT_Log,
    Please help DirectX problem,
    Thanks.
    There was this error in the log,
    3D Graphics, Not enough memory resources are available to complete this operation
    So likely this system doesn't have enough RAM for all the tests you are simultaneously trying to run.
    (there might not be enough main RAM assigned as video RAM)
    You could try running just the 3D test by itself.
