burnin tool test show"CPU, Incorrect 128bit (SIMD-SSE) floating point addition"
  • Yuanna2023
    • Jun 2023
    Hi ,
    When running burnin tool test show"CPU, Incorrect 128bit (SIMD-SSE) floating point addition" .
    It's AMD CPU Barcelo-R
    1.Run MemTest86 pass
    2.Run test with CPU only=fail ,CPU+ AUDIO=fail
    Version:9.2.1009.0
    May I know what components related? maybe provide a log for you ?
    thanks
    Can you try V10 and see if you still get an error?
    Might be a real hardware fault.
    Do you have more than one machine like this to test on?
    Can you send a debug log with just the CPU test running.
    https://www.passmark.com/support/bitdebug.php
