Testing a USB PCIe 4-port card. On 2 cards that have been reported defective, when the USB 2.0 Loopback tester is first connected to one of the 4 USB ports, the tester goes through a self-test/initialization. Normally it finishes with the Red Power LED and Orange Hi-Speed LED are lit solid. On the 2 failed cards, the self-test ends with the Power LED lit solid but the Orange LED flashes at a high rate. Is this symptom indicating where the problem is? John
Announcement
No announcement yet.
USB 2.0 loopback flashing speed LED
The Orange LED is expected to stay steadily lit once the USB 2.0 Loopback tester successfully completes its self-test. However, the persistent flashing of the Orange LED indicates the presence of underlying low-level issues that disrupt the enumeration process, resulting in frequent resets initiated by the host. Each time the host triggers a reset, the LED turns off.
Another, although less likely, possibility is that the tester is entering suspend mode frequently.
