3D fail "No operations reported in timeout period" problem
  • Matt Lee
    • Dec 2023
    Hi
    • The software version. BurntINtest V9.2
    • The operating system version. WIN10
    • When we do system stress , it will duplicate 3D error "No operations reported in timeout period"
    Is it any condition could cause this issue??
    CPU : INTEL ATOM X7211W 3.2GHz
    Memory : 4G LPDDR5 6400MHz
ID:	56381Click image for larger version
    V9 is no longer under support, you can try testing with the current release to see if there is a difference. There were some changes in V10 to try to reduce the amount of memory allocated in the tests when multiple tests are enabled that all require the use of the System Memory. However, 4GB of RAM is not really enough RAM to run Windows under any high load situation.
    See https://www.passmark.com/support/bit_low_ram.php
