How to skip series of scripting test and exit?
  • AlexID
    • Jan 2024
    If in script added only one test, all work fine: When stop-flag-file (BURNINTEST_STOP) added in "BurnInTest" directory, test stoped and "BurnInTest" exit.. If in script two or more test added, test stopped but BurnInTest not closing. How to fix it?
    my comand line
    bit.exe -T -p -r -s c:\burnintest\tasks.bits
    script:
    SETDURATION 1
    LOOP 1
    LOG "CPU Test"
    RUN CPU
    #RUN MEMORY <-- if uncomment it, program stoped, but not exit when "BURNINTEST_STOP" added
    EXIT
    • 335
    Believe we were able to reproduce the issue, can you try running the below build which should address this:
    https://www.passmark.com/downloads/t...g_20240130.exe
    • AlexID
      • Jan 2024
      Hi! Sorry for long response.
      Bug/feature still here..
      script not stopping after BURNINTEST STOP placed. (stopped only current test) and it trieing start next test... then showed Error and not exit from programm.
        • 335
        Made another change, can you try running the below:
        https://www.passmark.com/downloads/t...g_20240216.exe
