from bootable USB
  • AXTEK line Janos
    • May 2024
    from bootable USB
    Hello Everyone,
    I have a question about bootable USB drive, (if I installed the Burn In Test to USB and I start the program from drive) I would like to run 2D & 3D test but I fall in failure. The program cannot call OpenCL.dll (cannot not found) and Unable to start DX12 test.
    (I think the driver is missing and it is not include)
    Does it make sense to run these test steps in this case ?
    I have CPU - IntelĀ® CeleronĀ® dual core N3350 1.1GHz up to 2.4GHz
    My question is that I can only run these test steps if the drivers are installed ?
    Can I integrate them on the bootable flash drive ?​
    Thank you!
    • 969
    The 2D/3D graphics tests are among the tests that are not supported when running in WinPE, this is noted in the Limitation section of the PDF Guide. In addition to likely absent drivers in the bootable image, WinPE is a preinstall environment that is missing necessary components to run these tests.
