Using EXECUTEWAIT script command with batch files
  • MattP
    • Jan 2016
    I'd like to run the diskspd utility by Microsoft in between cycling the disk drives. The issue I am having is that EXECUTEWAIT opens and the immediately closes the command line without being able to run the diskspd utility. Here is my script:
    LOAD "C:\DiskTest.bitcfg"
    LOOP 3
    EXECUTEWAIT "C:\diskspd64.exe" "-Z4k -b4K -d5 -o1 -t1 -W0 -r -S -w100 testfile.txt >> results.txt"
    RUN CONFIG
