BurnIn Test 11 CPU Clock Frequencies Monitoring
  • zenmota
    • Sep 2014
    • 216
    On the CPU Clock Frequencies Monitoring it does not seem to refresh after a test (at least a CPU Test). I ran the CPU Max Heat Test then just the CPU Test. After that I ran just the USB Test. As you can see fro m Screenshot, CPU Freq. Monitoring never refreshed the Current Freq. Even when idle.
    We'll take a look
    • zenmota
      • Sep 2014
      • 216
      On the Clock Frequencies Page I noticed that the graph goes to 104.0s for Time and just stops. I ran the CPU test once, then ran it again for 30 minutes and it just stayed at 104.0s never moved. Also, the CPU Current Freq. never reset even though it was idle. Stayed at 5178.8. Have attached screenshot.
      • zenmota
        • Sep 2014
        • 216
        It seems like the first test you run the Clock Frequencies Page works fine, but after the end of the first test, it's just stuck there. It doesn't work correctly again unless you restart BurnIn Test.
          This will be fixed in next build release; CPU Frequency collection will continue if you restart testing after initial testing/reset.
          • zenmota
            • Sep 2014
            • 216
            Mine doesn't work like that. CPU Frequency Collection never works again after I run the first test. Even if I reset and restart testing. After I run the first test, I have to restart BurnIn for CPU Frequency Collection to start working again.
              BurnInTest V11.0 Build 1002 was just released. Can you give that a go.
              • zenmota
                • Sep 2014
                • 216
                When I first start BurnIn Build1002 the CPU Frequency is working with no test running BurnIn idle. Run a test and CPU Frequency is working. Test ends and click Reset. CPU Frequency is not working. Start another Test and CPU Frequency starts back to working. Seems after first test run, CPU Frequency only works when test is running. Seems like CPU Frequency should just be working all the time, no matter if test running or BurnIn idle?
