Temperature sensors not detected
  • idobenel
    • Jan 2025
    I’m using BurnInTest Linux V5.0 (command-line version) and encountering an issue where it fails to detect any temperature sensors.
    I’ve installed lm-sensors, hddtemp, and smartctl as recommended.
    These tools work fine when I run them manually and do report temperature information.
    However, when I use BurnInTest, it cannot retrieve this data.
    this is the main menu:
Name:	Screenshot from 2025-01-28 11-53-10.png
    and this is the temperature screen:
Name:	Screenshot from 2025-01-28 11-46-22.png
    Here’s my current temperature configuration in the config file:​
    ## Temperature settings
    <Temperature>
    ## Auto select which temperature sensors to watch
    AutoSelectSensors
    ## Temperature sample time in seconds (min 5)
    SamplePeriod 5
    ## Scale - use either Celcius or Fahrenheit
    UseCelcius
    #UseFahrenheit
    ## Stop testing if a sensor records a temperature higher than the threshold
    #StopTestOnHighTemp
    ## If not using AutoSelectSensors can add sensor names to look for here, must match what BurnInTest displays eg "CPU 0 Core 1"
    ## One per line between the "Sensors" tag (up to maxium 64), threshold after a ','
    #<Sensors>
    #CPU 0 Core 0,90
    #CPU 0 Core 1,90
    #CPU 0 Core 2,90
    #HDD 0,90
    #</Sensors>
    I’ve also tried commenting out AutoSelectSensors and manually specifying sensors under <Sensors> (e.g., CPU 0 / HDD 0), but I’m getting the same results.
    Has anyone faced a similar issue or knows what could be going wrong? Any help would be appreciated!
    Can you start BurnInTest Linux with the '-d' command line parameter and let it run for few minutes and then send in the logs?
    Temperature collection uses the output from the sensors and hddtemp commands in Linux.​ Can you also provide the output from those commands?
    • idobenel
      • Jan 2025
      Thanks for your reply.
      logs and outputs are attached.
      I do see a lot of errors like this in the debug log:
      Thu Jan 30 20:57:39 2025 - 610883 Packet was not an ICMP_ECHOREPLY (error -1)
      when it gets to GetHDDTemps, but I'm not sure what it means.
      thanks.
        • 335
        Note you are using a pretty old build of BITLinux (1003), can you try updating to the latest build (1017) and see if the issue still occurs?
        https://www.passmark.com/products/bu...x_download.php
        There have been some changes to temperature collection which may address your issue.
        If issue persists, can we get the debug logs from that?
        • idobenel
          • Jan 2025
          Using the latest build indeed worked.
          Thanks!
