BIT 11 Crash: No operations during test period
  • Tpd622
    • Nov 2021
    • 16
    I have seemingly run into an issue where BIT seems to crash after about 68 hours of testing. It seems to run fine until that point, and then it throw errors saying that there were "no operations during testing period" for numerous tests (but not all). This occurred across 7 systems that had identical builds, and i am working on getting a test rig set up for testing with the newer release that you have out. I will also attempt to run this test with debug mode on so i can provide that report as well.
    While this is not normally an issue (as most of our units will only burn for 48hours max, we do have some instances where we would like our systems to be tested over a weekend, and they may burn up to 100 hours + before they stopped.
    Any help you can give is appreciated.
    • 335
    Did BurnInTest produce any crash dumps? If so, can you email them to us to have a look?
    Could be a buggy driver if they all crashed around that same time.
    Could also be some software not releasing system resources so the system eventually runs out of RAM, or handles, or some other resource.
    Full log would be interesting.
    • Tpd622
      • Nov 2021
      • 16
      Hello. Apologies for the late response. It appears this may have been an interaction with an old version of Windows, as we have updated our images and no longer seem to see this issue anymore with 24H2.
        Glad it got sorted out.
